Super product!
One of the first accessories I bought for my camper was a Sewer Solution. It works well and I much prefer it to the standard 3" gravity assisted dump line.
The downside, other than the need for a pressurized water source to operate it, is that it's a little slower than the "standard" dump method.
On the up side, it will pump uphill (about 36" if I remember right) and the water jet nozzle swivels so that you can back flush your black water tank. After the contents of the black tank are gone, the SS's drain line is automatically cleaned out by the pressurizing water. It's altogether cleaner and neater to handle.
I've read of individuals connecting 1" PVC piping to the SS outlet and pumping a long ways with it. Some use it to dump into their home's sewer system.
I bought a 45* clear elbow and install it ahead of the SS on the camper's drain connector. It saves wear and tear on the SS's connector tabs and it also makes it easier to monitor progress.
I bought mine directly from
Sewer Solution as a factory reconditioned unit. Saved a few $$$ and it works as good as new.
One of the best things I've picked up for the camper thus far.
Tim
