I have a 2001 4x4 with 150000 miles on it. 3. 54 gears and stock tires. Transmission was replaced by the dealer approx 55000 ago. I have only recently added a Smarty as the only power adder. I am more than satisfied with the power now. My full throttle shifts are firm and quick as they should be. Part throttle shifts (half or less) became slippery when the Smarty was added. They were so-so before. They were soft before, but the extra power at part throttle seems to be a bit much.
I set about solving this problem myself. The only "kit" I could find was the transgo kit. When I worked at a shop as a tech years ago, my boss had several heated discussions with Gil about his products and I haven't used one since.
I got several parts from Sonnax. I installed the billet piston, 4 ring accumulator piston, and the switch valve. I also turned the pressure up a little while I was in there. I wasn't sure how far I could go. I'm at 62 idle warm and 138 full throttle. There is very little pressure variation between the ports and all shifts including lockup are good except for the 1-2 shift. It is still a little soft under part throttle. All shifts are perfect at full throttle. I have played with the cable some and I seem to wind up where I started as the shifts get erratic if I go too far one way or the other.
I have been in the pan several times and there are no signs of metal or clutch material. The bands are adjusted properly and I have added a different band strut. The band seems to be in real good shape as well. You can still see the machine marks on the hub and the band is an as-new color.
For now all I would like to do is firm up the 1-2 shift a little. I plan to get the transmission done in the future, but I really see no need at this point.
When I spoke to Stefan Kondolay on the phone, he recommended a valve body for now, but I hate to spend the money if I am going to do the whole thing once the transmission fails anyway. Any help would be greatly appreciated.
