Gear Shift Knob
OK, here's what I did on my 96 5 speed. It should work on your 6 speed. Remove the cap on the knob, then take the nut off. It should come right off. I found a used hurst shift handle at the swap meet but you could buy a new one at any auto parts house. Then I reamed out the hole to fit the nut that I took off. I put J-B weld in the hole and then mounted the nut flush with the bottom of the handle. You have to let it dry about 24 hrs to set up and then put on the handle. I like mine and it's easier to grab and shift. Hope this works for you.
Silver Streak
PS any questions email me at -- email address removed --
