Hi, thanks for all of the help with the exhaust system. I now have another question. My 92 W-250 has a 4 speed automatic transmission. It has been shifting in and out of overdrive between 40 and 50 mph. It will shift up like it is supposed to, but as you accelerate, it drops back down from 4th into 3rd. If I do a full throttle acceleration, it will shift just fine and not kick down. I have had it kick down as high as 55 mph before. The truck actually slows down and the engine revs up. I have serviced the transmission with new fluid and a filter. It mainly does it when it is cold outside. Like today it did it for over 30 minutes and I finally just shut off overdrive and ran in third. The truck has not had many pulling miles, just highway miles. It does shift very nice and solid. Finally it will not act up when I am towing a load over 4,000 pounds. Anyone have any ideas???
Jeremy Sweeten
1992 Dodge W-250 4x4
Cummins Diesel, intercooled,
LE Package, 165K, AT, Warner Hubs, 3. 54 limited slip differentials, 3" straight pipe, K&N air filter
Jeremy Sweeten
