Engine/Transmission (1998.5 - 2002) shifting problem
Engine/Transmission (1994 - 1998) Fuel Plate
My brother-in-law has the 99 Dodge with the automatic and for the last several months when he takes off slow the transmission shifts fine but when he takes off fast it does not want to shift from 2nd to 3rd unless he lets off the gas? Any thoughts would be appreciated.
Don
mine does the same thing, only from 1st to 2nd. not trying to jack the thread, but i need to find out too. anybody know???
The first place to check is the TV cable adjustment. This is a very sensitive adjustment and small changes make a big difference. If you are not comfortable doing this call and I can walk you through it. It is an external cable adjustment no tools required.
Josh
www.dieselperformancesolutions.com
'95 trans slow to shift
I'm having problems with my 1995 transmisson shifting from 2 - 3
the trans fluid is a little high, it's 20 - 30 deeze greeze
here in CO. Changed tps and an adjustment from a mechanic who
decreased volts on tps to . 5 volts? or . 4 volts? He monkey'd around with
something else; because after his adjustment it sticks on 2 -3 shift.
Of course, it does not go to 4th gear until I have temperature.
126k miles, 2 transmission oil changes no heavy towings,
K & N air cleaner, no cat
