Those that have shimmed their center support bearing ("hanger bearing") on a long box Ext cab truck..... how thick of a shim did you use?
Can one use too thick of a shim (1/4", 1/2") and make it worse?
The shim goes between the center support bearing and where it bolts to the support, correct? I would guess one needs longer bolts?
I just had my driveline RnR at 205K miles on my 96 5sp. Replace the factory joints even though they had very little wear and were not dry yet. First time anything had been done to the driveline with lots of hard miles. The CSBearing was fine and left on.
I still have a shudder at low rpm (1400 - 1600) and heavy foot.
Thanks for any help.
jjw
ND
jjw
ND
