Engine/Transmission (1998.5 - 2002) Shock question? rancho
2nd Gen Non-Engine/Transmission Barry, new truck is here!
I have purchased a set of rancho 9000s for the front of my truck from shucks. Well pucky I didnt figure in the spacer. I have a leveling kit on my truck. Will this shock work or do I need a different one. The way i figure it is the truck is about the same ride hight as the gasser 2500 so it should work. A promp response will help for its at the car doctor right now on the lift. TIA
Shocking
Jack the truck up from front center, with the front end in full rebound position, if the shock will bolt up in the fully extended position it will work. bg
