Pull the P/S & vacuum pumps as an assembly. Remove the driver's side battery and intercooler tube, disconnect the vacuum, oil, & P/S lines, & the brace underneath the pumps. Then remove the two bolts holding the vacuum pump to the gearcase & pull the pumps out from the top. Separate the pumps on the bench. To reassemble, reverse the process.
