Ready, Set... DEBATE!
Thus far most of you folks like the bilsteins 5100's
I like the rancho's for being adjustable. ($99/each)
I like the Bilstein's as they are not-adjustable and cheaper! ($75/each-ish) and the majority of you folks like them.
My Habbits:
99% unloaded, City driven, racing here and there. It's rare that I do go off road with this truck, if It do, it's a rolling grassy fields on a farm or something.
Nitto's 285 tires. 60PSI up front, 45 in back (unloaded). When I do load up, I jack up the PSI to about 60-ish (64-is the tires are warm already)
Original shocks are still installed. Either I'm just used to the rough ride or they are still "good".
However, some roads it just beats the crap outa ya and I"m looking for some better traction when you get on the go peddle as she gets a little "hoppy" at times when on less then perfect roads.
My question is, Can the Rancho's on level "1" get to a softer ride then the bilstein's? And naturally when turned up get to a harder ride?
I'm leaning toward the bilstein's only cuz I've spent enough money on this truck this month and I still have to do a diff/motor/transfrer case fluid change prior to my long road trip at the end of next month.
And the incab adjustable rancho. I have and air tank already, can they be configured to use that air system?
My Habbits:
