2nd Gen Non-Engine/Transmission Shocks
2nd Gen Non-Engine/Transmission gauge question
2nd Gen Non-Engine/Transmission Door rust and possible solution
I can't afford Bilstien's, so what are the next best for my truck? I have thought about the adjustable Rancho's etc. . but I don't want to buy and be disappointed as these things are expensive and I want them to last a long time.
Thanks, Ron
nps said:
I've got Rancho 9000s. Very happy with them, but only 10K miles on them so far.
I've run 9000's on other trucks before and loved them - but HOW do you adjust them on our coil spring trucks????
No problem on mine - the adjuster knobs on the front are below the coils. I usually don't adjust them.
The rears I adjust when empty or towing. I can reach around to them without getting dirty or on the ground.
I just put Rancho 9000 on my Dodge diesel Class C Motor home
I just went on a 5650 mile trip In my Dodge class C motor Home with the rancho 9000 shocks and put the air compreser under the hood and the control under the dash. Works great but the front leaks off a bit In 24 hours. Will half to check this out. This made the Motor Home a lot more stable and worth the investment. I have air bags also on the rear. I did change the tires to 10 ply and that help also. :D
