The tip for the front installation is be sure to have the correct tools. You'll need a 19mm closed/open wrench. A socket will not work. Also, and this is the biggest pain, you'll need a 6mm metric allen wrench to keep the shaft from spinning when you tighten the nut. Also, no need to remove either battery to get the towers out. The passenger side you should be able to compress the new shock to install. The driver side you better be big and strong or have a buddy or two available.
