I have seen 240 volts heaters go up to 4000watts.
A freestanding woodstove will pump some heat out.
A friend has a 3500sqft garage with a 20'+ ceiling, and he has a small wood stove in there to heat things up. There is free wood everywhere if you keep your eyes open. I used to keep the last house warm all day with a couple of cut up pallets. A freestanding woodstove will pump some heat out.
I have a propane heater that I use in my 2 car garage for woodworking. After all I have read about toxic fumes and the lack of oxygen from these open flame heaters, I have quit using it. As I understand it the only safe gas heaters are the ones that are vented to the outside.
Is this not really an issue?[/QUOTE]
It is an issue. Good point.
Propane heaters will work just fine, just make sure you have some ventilation and go outside often.
hey guys, looking to get a good heater for the shop, 24ft x 24ft . looking at a 240 volts heater if posible,no gas at shop. shop is a wood build & siding. no insulation. what are you guys are using. thanks for any info
I use one of these 100K BTU heaters on propane: LF24 Unit Heater | Heating Products in my 60' X 80' insulated steel building shop with 14' high overhead type doors. So far this winter, it's used about 30 gallons of propane with the thermostat set on 52 degrees.
Bill
How much did you give for that? A friend of mine has a propane chicken house heater in his shop. It does not have to be vented to the outside. He gave about $600 for it. My shop is similar size to yours (50'x90') so a similar BTU heater should work for me.
