Hi Nick here , this is my first post so bare with me. I have several issues going on with my 06 2500,5.9,Sport,2 WD, 192K miles,stock truck
This truck has been a great vehicle since the day I picked it up NEW back in 2005 in Daytona Beach Florida it has been a Florida truck it's entire life ( no salt or
harsh environments). I do all my own work and know this truck fairly well( I least I thought I did )
I will use bullet items to make it easier to read, OK here it goes
the symptoms are :
test/diagnosis and work I performed :
parts I just replaced :
Results :
I'm not a stranger to repairing vehicles ( I was a fleet mechanic for 15 years ) and have build street rods,owned many cars and trucks etc, but I'm over looking
something. One question that comes to mind for all of you good trouble shooters reading this thread is "what systems/components are wired directly to 12 volts without being fused / overload protection ? The size of the arch/ spark when the battery cables are reconnected would most certainly blow a fuse, not sure what the amperage draw is being I have to get a new quality multi meter.
the symptoms are :
- have a short that drains both batteries in 1 1/2 days
- truck has 2 Auto Zone batteries that were 4 years old and both batteries did not come back after trying to charge them
- when battery cables are removed and then reconnected a major arch / spark occurs
- turn key on to start and all gauges sweep ALL the way/pegged to the max and check engine light along with many of the other cluster warning lights are flashing
- cranks over fine but vehicle will not start
- no blown fuses check every one
- checked all battery cables with TIPM lead wire disconnected (no arching )
- checked starter solenoid and wires " " " " " " " " " " " "
- checked alt. lead wire " " " " " " " "
- checked both new batteries for voltage and load tested both OK (they are on a battery tender )
- checked TIPM ,no signs of anything burnt anywhere
- disconnected every connector in the engine compartment
- " " the 2 connectors at engine PCM/ECM than touched the power lead to the TIPM and it still arches/sparks
- just installed 2 new group 24 marine deep cycle batteries and both batteries are good ( charged them before installing )
- Dorman TIPM correct part # that matched up to the OEM # on the org. TIPM...
- NOTE: according to tech at Dorman the TIPM did NOT have to be flashed he stated to turn the key on for 12 seconds,then off for 12 seconds,then start the engine
- new Bosh 135 amp alternator
Results :
- still significant short / arc when battery cables are disconnected and reconnected
- all gauges seem to be working OK
- NO check engine light flashing or staying on
- engine still won't start
