Well here's the old sig. I'm gonna BOMB my Sig, so it's within proper specs.
Merrick Cummings Jr
Cop Magnet, Head Turner, Import Eater...
Works Harder, Heavy hauler,, pulling a 19,000-27,000 pound Flatbed Gooseneck
98. 5 Dodge 3500, 2wd 5-Speed Changed for 6-speed, 6-speed has the small 5-speed input shaft, Light Driftwood
Before Stacks :-lafAfter stacks
Not exactly bone stock
5"Stacks, 6' tall, runnning on outside of the bed:-laf Transmission and Rear-End, Amsoiled! 3. 55 "Tight" Limited-Slip Differential. A. R. E. Camper w/side pop up windows,Took off the camper for now to haul Gooseneck trailer Michelin LTX A/T 245/75/16's, Autometer Gaugeworks 3 Gauge A-Pillar Pod, Fuel Pressure> Boost Pressure> EGT GaugePower Edge COMP Diesel Dynamics Stage 1 injectors
Big Honkin' Air Filter, ATS Manifold(Don't put your pyro there, closer to the turbo), ACP Street Legal Clear Tail lenses. , Tireflys on valvestems, 600 watts of Bass on the backseat. (Removable box) (2, 300 watt 10" Kicker VR's) Precision Power 160wx2 Amp underneath driver seat (for subs) Eclipse Head Unit (CD/Tuner), Kicker IQ900 EQ, 6x9 3-way Eclipse 90w in front doors, Kicker 5" 2-way 70w in QC doors, Eclipse 45wx4 Amp underneath pass. seat. Yah,, The radio in my truck makes the stock infinity seem like childs play.
1998 Yamaha Warrior (BOMBed, Hi-Po Cam, Piston, Gears, Aluminum Skid plates, New Plastic, Drilled front brakes Brakes, Exhaust (Sounds like a 350 Chevy with glasspacks), Intake, Wider Axles, Offset, and wider Rims, Low profile Tires, Shocks Revalved "Tighter" and Springs), Top Speed over 70 MPH, 2000 Honda Recon Stock
2002 Yamaha Raptor Just a perfect combination stock,, I like it,, It's quiet and fast,, and the Torque curve is flat!
My Truck page
NEXT: BigSaints MIL F. P. Gauge install, I have installed dual lift pumps, and I will be putting one gauge for the first pump, and one gauge for the Second pump. (I just need to find a 0-30PSI 2 5/8" full sweep fuel pressure gauge)
Example 1 2 3 (This one is hard to commit to)
Full Severe Service Brake upgrade kit from EGR. New Front Kevlar Pads, and drilled rotors, w/bearings, new rear pads and Bigger rear wheel cylinders, and synthetic brake fluid.
New South Bend Clutch, Con OFE 13" (6-Speed clutch) the 5-speed conversion clutch.
I really would like to thank DTT and South Bend Clutch for their Help, Advice and Parts.
Andy and Doug at ADT are tops,, excellent straight forward service.
Glenn Maurer at EGR is excellent also,, His brake upgrade kits will make your truck stop like it was meant to.
Was wrecked Now getting ready to get off the porch... (I'm now off the porch but just wondering around lookin' for more money to spend on my truck)
E-Mail Me
**Houston Drag Races** Nov. 2nd
Merrick Cummings Jr
My Truck page
E-Mail Me
