I'm looking at buying a 04. 5, quad cab, 4x4, short box, automatic from a Dodge dealer. 60K miles on it. Truck has new factory-spec Michelins.
I noticed a vibration that feels like a driveline vibration (not a tire vibration) as it comes on at 64mph and goes away at 72mph. Truck is very smooth at all other speeds (tested up to 90mph. )
I perused this forum, and see others have had the same issue, which may or may not be fixed by a driveshaft angle shim (rear driveshaft I'm assuming?), or even a new axle assembly. I read where various dealers have tried replacing drive shafts/u-joints/etc. Some posters talked about the front axle systems, so I'm not clear if the culprit is front and/or rear.
The truck is a "Dodge Certified Used Vehcile" which my understanding is it has a 3 month. 3K non-deductable warranty. The salesman of course stated "we will fix the vibration" when I mentioned it. I'm still test driving it (they let me take it for 2 days!)
Should I go ahead and buy the truck, and let them "attempt" to fix it? Should I avoid this truck altoghter?
Edit: It's a tough decision, because this truck is extremly clean, is the right color, and is priced lower than everything else comparable. No other issues except the vibration! Decisions, decisions... .
Thanks!
Scott
Thanks!
Scott
