Thanks for the replies.
Yes, they are planning on insulating with the rigid board on the inside of the foundation wall before they backfill the inside. Will go all the way down to the footing. The plans also call for a 10 mil vapor barrier under the slab.
I'll probably have to lay down on it once in a while if I need to wrench under the truck or car. Probably won't have to sleep on it though unless I behave really badly and am sent out to the garage for the night without a pillow.
It is sounding like it would be a wise choice to put this down under the slab as well as inside perimiter of the foundation wall. Also looks like there may be more than one choice when it comes to compression rating of these blue and pink boards. I assume I want the higher rating since it will be supporting the weight of my truck.
Assuming this stuff comes in 4x8 sheets I'll need about 15 sheets. Am I looking at $20 per sheet or more like $40 or... Having a hard time finding a price for this anywhere on the net.
I also asked about the drain idea and the answer was a definite NO. Would be easy because the sump pump drain pipe going out to the storm sewer is 4 ft under the middle of the new garage. They will not let me tap into it because it drains to a local wetland area and they are afraid of oil and chemicals going down the drain.
-Deon
