The DyanLoc hubs are the actual locking hub that is made by DyaTrac for thier free spin kit. Technically, they are a more expensive, high quality locking hub. Though they also offer a less expensive Warn locking hub option for their kits. Obviously Warn (you HAVE heard of them, right??...lol) has ALOT of locking hubs out there with only a very small percentage of failures, but again I wanted the advantage of locally made and sourced parts as well as one that would fail in a locked mode versus unlocked mode in the rare case of failure. The 3 big choices (though IIRC there are even more then 3 kit manufactureers for our trucks) for free spin kits are the DynaTrac, Spyntech and Yukon,,,if you google/compare them, you will have LOTS to read. Everyone seems to be relatively happy with their choice of kit, as well they shpould be given the $$ involved.
In short, if you have the money, do not necessarily expect a financial payback in fuel savings (though that IS there to some degree), run oversized wheel/tire combos which subject the unit bearings to more stress then designed for, and also tow a trailer so that you could benefit from the use of 2wd LOW gearing while backing up, then you should seriously consider a free spin kit upgrade. Another benefit is a slight increase in ease of steering.
