Hi Guys,
I custom ordered a 2001 4x4 Sport LWB manual transmission truck, the only thing I would have changed was maybe the cab clearance lights, sliding window and 6 speed transmission.
Now it has Michigan rust, 165k on the clock and is approaching 20 years old.
I purchased it because I wanted the legend and I knew the common rail would be quiet and sound like a VW diesel.
Now I have the bed and cab to replace because of rust and using it as my primary all year daily driver. There are also some things that need to be fixed on a 20 year old truck, i.e. never replaced the clutch, vacuum pump, injectors flow tested or upgraded, stainless steel brake lines, drivers seat and some interior pieces are not perfect that I could hunt for.
I would need to build a pole barn to store it and work on it, just to have a nice looking 20 year old truck that has no rust and can drive anywhere and pull any trailer. It would go up in value from $6k to $30 if I make it look perfect.
I have a lease truck to drive all year, don't need another car/truck but will never want to spend $80k just to have the automatic transmission **** to bed in 4-5 years of use. I have had 18 years of 0 engine and transmission issues. I live in a small town and have a local dealer that does not have good service.
I am torn as to what to do and have several buyers that want the truck, if I was buying I would want a 24 valve with a manual to pull... Nothing else is going to pull or last. The new aluminum 6 speed is not as stout as the cast iron NV transmissions, that said NV is out of business so that too is a concern.
What to do...
What to do...
