Engine/Transmission (1998.5 - 2002) Shudder at high loads
Engine/Transmission (1994 - 1998) Attn All Central Valley
Maybe someone can tell me if this is a trans or lift pump problem.
At higher loads, i. e. highway speed in top gear, the truck bucks and shudders when more fuel is added to accelerate. I have not noticed a similar problem at low speed. Everything else seems normal.
Does anyone have an idea what might be wrong, or getting ready to fail?
BLACKRAM
I had the same problem before DTT rebuild. Pulling 10K load up a steep grade out of overdrive anything past 1/2 throttle the truck would start shuttering. I had assumed it was a lockup problem. I do not think it is a lift pump but you really can not rule it out without a pressure guage. I would call DTT and get another opinion. When my trans. was rebuilt DTT's Smart Controller was installed which controls lockup,overdrive etc. and I have not had any problems since. What gear were you in when this occurred?.
Dave
