Shutter Mystery, At 445,000 miles my 03 2by4 6 speed manual, Diesel Dodge developed a Shutter. Felt like I'm running off the side of the road on the grooves or I got tire chains on. Between 15 to 30mph on the speed up or slowing down,But If I speeded up real slow no shudder. Above 40mph everything felt normal. I could feel it in the seat,
the arm rest the dash but not in the stick shift. The whole body shuttered. Tryed inflating my air bags to different heights.
The shutter started when the temp. was 61 now the temp. is 34. so temp. has nothing to do with it. Man I spent 3 days tryin to find the cause. First I read all the posts here on the causes and cures.
I took the driveshaft out, checked each U-joint, all good. Replaced the center bearing that holds the driveshaft. Had some deteriated rubber, I droped the center bearing 1/4 in. with shim.
Took the front wheels off, filled the non-servicable hubs
with grease through the speed sencer opening, checked for any play in steering components,all good. Checked transmission fluid level, Removed cover of rear differantial, inspected inside gears, Gee! no wear at all worth mentioning, good for a 2 million at least. Rotated all tires. Took one rear wheel completly apart,because it had a very little rubbing sound. everything was good. If I had any hair on top of my head I would have pulled it out by now. I gave up on tryin to find the problem. I went and hooked up to a 31ft. travel trailer, going to deliver it to a dealer, When I started out on this trip
the truck shuttered so much I figured I wouldn't make it a hundred miles before something explodes,Then I would know the root of the problem. I asked myself,? "Do I really want to go this route?"
I figured I had no choice. 100miles later the shutter had stopped, I went on and delivered the trailer and returned home
1,000 miles in all and there is no shutter at all, ever, I had 300miles of shudder and now none So is this in remission? I sure hope not.
It makes no sence at all, I told my Wife my truck is no longer a big Ram Male, but rather a PMS prone Nanny Female. Now does anyone have any ideas what this shudder was? I'm stumped. One thing I didn't look into is power steerind hoses vibration. I don't know anything about that and just elimated that from my list of suspects. I just don't think that was the problem
