All,
For all of you with the Shudder/Stumble problem.
Given that this problem can be caused by several things
(boxes, transmission, fuel pressure, just to mention a few), there
is one other thing you might check.
The Engine Coolant Temperature sensor.
( Near to the T-stat housing )
The ECM calculates the injection timing upon several inputs.
RPM, IAT, Throttle, calculated load, AND engine temperature.
From what I've seen here, it seems that the shudder occurs
mainly in colder climates and under light to medium loads.
I would dare to say the injection timing is set too high for
those operating parameters.
Basically you need to check the ECT sensor like you would do
with the IAT ( Their outputs are the same)
For more information look here:
https://www.turbodieselregister.com/forums/showthread.php?s=&threadid=11726
In simple words, if the ECT sensor reads lower than it should,
then the ECM calculates the timing too high, thus you get the shudder in the cold and under light loads.
Marco
Marco
