Shutdown "Chirp"
Remedy for Flat, Oxidized Emerald Clearcoat?
How to check Tie Rod Ends
I have a 2001 automatic. Whenever i shut it down right before the engine stops you hear a loud "Chirp", thats the best way to describe it. Sounds sort of like metal rubbing. I have 12k miles on it and his done this from the day i got it. Does anybody elses truck make this noise?.
It's the serpentine belt chirping when the engine stops quicker than the belt. Should be no problem.
2001. 5 (del'd 1/31/01)2500 SLT Quad 4x4 155"WB, ETC, auto trans (DGP), tow pkg, camper pkg, MOPAR bedliner, 4. 10s, Patriot Blue ...
Jed DuVall
WHEN I HAD MY 98, 12 VALVE I CHIRPED, WITH NO PROBLEMS FOR ALMOST 100,000 MILES, ALTHOUGH I HAVE 3,000 ON MY 2001 AND I HAVE NOT NOTICED THE SOUND YET.
I was told at a campgrond the goodyear gator-back belt will stop teh chirp. I can't say for sure just passing on what I was told.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
My truck did that until I figured out that it only chirped with the A/C on. Now I turn the A/C off before shutdown and I've never had another chirp.
Mick
Mine did it with or without AC on. Changed to the Gatorback back, no more chirp #ad
<font color=forestgreen>2000</font> DODGE <font color=forestgreen>RAM</font>, <font color=forestgreen>2500 HD</font>, 4x4 SLT, Reg. Cab, <font color=forestgreen>Forest Green</font>, Agate interior, Cummins ISB, Auto, Shift-on-the-Fly (241HD), 4. 10 LS, ABS, Trailer Tow Group, Camper Group, Michelin; DC: Fog Lights Kit, Tow Rings, Under Rail Bedliner, VentVisors, Splash Guards, Cold Weather Cover, & Mats.
<font color=forestgreen>After-market</font>: JRE 4" Exhaust, Van Aaken, High Idler, Heavy Duty Idler Pulley, Gatorback Belt, Painless Wiring, K40, Viper w/AutoStart, Clarion 6 Disk CD w/remote, UnidenCB w/Francis antenna, Draw-Tite Activator II, Alpex 255TC2C Air Horns, Continental BedRails, Delo 400, HOWES, Liquid Glass.
BigDaddy's Ram #ad
New England RamRiggers
<font color=36648B>2001 PT Cruiser Limited Edition</font>
my '97 chirped and my '01. 5 chirps #ad
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
1975 Toyota Landcruiser, ARB Air lockers Front & rear, 400 Small Block, SM420 4spd, Stock LC transfer case with 2 or 4 high and 2 or 4 wheel drive Low gears, 15. 5x36" Radial swamper on 12" rims, Custom front & rear bumpers, Roll Cage, Warn 8274 8000# winch, 2. 5" spring lift, 2" body lift. Premier on-board power welder, on-board air, 4-wheel power disk breaks, power steering, Lot of fun.
The Gatorback IS the answer..... What bugs the bajesus out of me is this... . Why can't DC, or Cummins, just give us a decent belt?... . Is this too much to ask for a 35K truck... . ?... Can't we just get-a-long? #ad
Colin
2001 Quad,4x4,AT,4. 10LS,LB,Loaded enough,stock,mostly... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Specialized FSR PRO Stumpjumper,Cannondale F2000, Loaded
MTD Lawn tractor with flames
12' fishin' boat, loaded. .
The "99" auto did the chirping thing periodically, mostly when it was warm. With almost 5000 miles on the "01" I only heard it chirp once.
"01" Forest Green QC/LB ETH/DEE,4x4, 3. 54LSD, VDO (boost, pyro) Westin SS Nerf Bars and Grill Gaurd, Delta tool box, K&N.
00 28' Jayco 5th Wheel, 86 "Classic 16" Alumacraft, 00 Honda Rancher
Towing with a slight "edge" on the competition!
Go for the Gatorback Belt, it eliminates the squeak completely. The part number is #4080810 8PK2055 (That's for a truck with A/C).
Y2K Quad Cab SWB 4X4, White (aka: The "Iceberg"), Auto, 4. 10, Leather, Loaded, Line-X, KNAACK Crossbox, Smittybilt Nerfs, BFG 295/75-16's, DC Bug Guard, Rancho 9000's.
I too suffer from the dreaded "Chirp". Started at about 4,000 miles. Brought it to the dealer and he said it was from the fuel pump #ad
and that he has tried to get rid of it in another truck to no avail. He did say it wasn't detrimental to the truck.
I'm leaning towards your explanations as the actual problem. Either way I know its not harmful just annoying. #ad
Question: Who makes the gatorback? I think it's Gates but I'm not sure. #ad
Kevin MacGranor
2001. 5 D2500 QC SLT 4X4,Auto 295/75r16 BFG AT's, Century Cap, Bedrug. , Alpine Head & Amps w/ Boston Acoustic speakers & JL Audio Stealthbox center cushion Sub.
ON ORDER: Reunel rear and Denver Offroad front Bumpers, and Autometer Sportcomp gauges from Jannetty
I think, for the most part, that it is ONLY The Automatic Cummins' That chirp.
With a few rare exceptions for manual trannies.
my 98. 5 5-speed hasn't ever chirped.
MerrickNJr
My '99 chirps almost every time I shut down. Dealer said it was normal. I'm going to try the gatorback.
'99 2500 4x4 long bed quad cab auto with sport package.
My Toys
I a, stealing a phrase someone else posted several months ago about this same topic.
"The chrip just reminds everyone the King has arrived. #ad
Y2K Black 3500 4x4 SLT+ Leather ETC/DGA DMF/DSA Luverne SST Bars
'64 Plymouth 426 III (Max Wedge)
'79 Chrysler 300 T-Tops NRA Member
I thought goodyear made the gator-back.
Just bought a Goodyear Gatorback thru summitracing.com for way under 30 bucks.
2001 QC4x4 eth dee slt+ 3. 54 blk agate leather Warn transformer mount Hella 4000s, Hella 530 backups, Optima redtops Toro liner, jacobs ebrake, wired front and rear for Warn 9000 winch, backup lights inset into rear bumper,bumper powder coated silver vein, bedliner on 6" of rocker,custom aluminum console with Garmin Colormap GPS and EGT built in,Horton fan,MagHytec diff cover
