Just installed a new shutdown solenoid and after installation the solenoid still would not pull up when ignition is bumped. I know that the red wire that goes to the plug is ignition which holds the arm up, the white wire runs off of the oil pressure switch which tells the solenoid to pull the arm up when spinning the motor over, and that the black is ground. I took a test light and tested all of the connections and they all work properly but the arm will still not pull up. If you pull the arm up with the ignition on then it will stay but it just will not pull up by itself. What could be the problem?
