Engine/Transmission (1998.5 - 2002) shutting off trouble and possibly missing
Engine/Transmission (1998.5 - 2002) New to this forum, truck died
Engine/Transmission (1994 - 1998) drive shaft carrier bearing
i have a 2001 cummins 24v i have 150hp injectors , a quadzilla adrenaline, bd monster injection pump, . 093 tubes and fuel lines, industrail injection 62,14 silver turbo, afe intake, 5 inch straight pipe, air dog 165 fuel pump, if i have the truck on a higher setting and rip on it and come to a stop sign and push the clutch in to stop the truck will stall and i will have to crack fuel lines loose and crank the nuts off it to get fuel up to the injectors and tightin them to get it started, what could this be? also wen i have the quadzilla turned up past maybe three at around 2300 itll start popin and sputterin but if you pull out and rip on it fast itll wind right up to 3200 rpm, what could be this issue too? :mad:
How is your fuel pressure when this is happening? I think the first problem is airlocking the pump, seems quite common with the Quadzilla Adrenaline though I havn't had it happen to me yet.
I used to run a quadzilla adrenaline a few yrs ago, and ended up selling it because I was having similar symptoms, such as stalling and dying when in reverse or less than 10mph. Happier without it really
