Sick auto fixed!
EZ POWER!!!
DIFFERENTIAL
Towed today first time with EZ. Perfomance is beyond belief. Also disabled wastgate. Over a 60 mile trip milage was up 2 mpg. Finally woke up the sleeping bear! Thanks Bill K. This is a good bomb for auto's.
2001 2500quad4X4SBETC auto KN Black Leather loaded Boost and EGT gauges EDGE EZ
[This message has been edited by buttugly (edited 03-10-2001). ]
Buttugly, When towing what notch did you have the EZ set to? I just installed mine but have not towed yet. I was told not to tow in the most aggresive position with an A/T.
I towed in the most aggresive. . have not tried the others yet. Edge did not advise me NOT to tow in most aggresive! Need feed back about this.
Guys
When towing what works for one guys does not necessarily apply to the next guy. You have to consider apples to apples ie/towing weight
The Chrysler pcm does not recognize the extra power, when towing in od , usually around 55-65mph you lose the ability to downshift.
On a standard trans you can downshift , on the automatic you should also manually kick it out of od when rpms start to fall below 1700 rpms.
Bill Kondolay
Diesel Transmission Technology
