Side mirror loose & needs tightening
AutoMeter Ultra Lite 0 to 50 PSI Gauges *Shipping!*
Part Number Please
Finally signed up and have my first question.
Does anyone have a fix for a loose side mirror. Mine is getting very sloppy and is really getting on my nerves. Is there an adjustment that can be made to fix this problem? It's the chrome electric adjusting mirror.
Thanks,
James
1997 12V 4x4, Auto,TST #6, DiPricol boost,Pyro,transmission Temp pillar mounted, TC Switch,BD converter, BD valve body, K&N Air,Silencer ring gone,Custom exhaust w/16 S/S cone tip, 2" frnt lift,Air ride suspension, S/S rocker panels & fender flares, 285 75r 16 mounted on aluminum wheels,Kenwood stereo/12CD/amp,Leer canopy,Elkhorn Camper,DIVORCED hmmm... More to come. . Injectors next!
KLRRAM==Welcome aboard Mr. undervalved! The inside door panel has to come off, then you can get at the mounting hardware for the mirrors. It helps a bunch if you have a service & repair manual-(DC), to do this. I would also use loctite or equivilent on the bolts, just pull 'em out one at a time, clean the threads, a drop or two on the threads, and re-install them. Be real careful when you tighten them up, torque to specs, as you can "crush" the inner and outer panels together real easy.
2K1 auto 4x4 QC dooley--stock as a rock--except for shiney stuff.
There are repair/rebuild kits available through your local DC dealer for your loose mirrors. They are designed to fix the loose mirror problem and include all new and improved bushings, screws, clamps, etc. They come with instructions and are easy to follow.
98. 5 24 valve clubcab custom dual exhaust w/5" tips, Autometer pyro & boost gauges, K&N filter, 3" lift kit, 33"x16. 50"x16. 5" Dick Cepek Fun Country Radials
Thanks Frijole and Dodge-Tech! I'll finally get this problem taken care of!
