Engine/Transmission (1998.5 - 2002) (sigh) 'nother lift pump ???
Engine/Transmission (1998.5 - 2002) pyro gauge install
Engine/Transmission (1998.5 - 2002) vp44 core charge?
Apparently, an updated lift pump was adopted by DC in mid-'01 to address the high failure rate of pumps in our 24 valve engines.
Question is, WHAT were the "improvements" provided by the revised pumps, and have they been effective? As the owner of a new '02 truck, I am more than slightly interested in knowing if *I* face the same prospect of premature lift pump failure, or have lucked out with a later unit that sidesteps the issue...
Comments? Anyone with the post '01 1/2 24 valvers had lift pump failures?:confused:
Newest lift pumps
Sorry to dissappoint you, but even the very newest lift pump is still mounted too high and too far away from the fuel tank, and will suffer from the same failures as the earlier pumps.
My first pump lasted until 14. 5K, the second until 18. 9K, so I added a pusher pump to keep the second one alive. Then at 22K, I had to get some warrantee work done, so I removed the pusher and many other mods. The second lift pump couldn't develope over 5 psi on it's own, so it was warranteed by the dealer.
The third is getting weak after only a few hundred miles, so I reinstalled the pusher pump today.
The only answer is to add a pusher pump, and feed fuel to the lift pump. Install a fuel pressure gauge to monitor the pressure.
Hope you enjoy your new Truck.
Greg L The Noise Nazi
(Sigh!)
Thanks for the input Greg...
Out of all the reading on the subject to date, 2 truths seem to have emerged:
1. Some sort of pusher pump, located as near to the tank as possible, and supplying GOOD flow at around 5-9 lbs is needed to assist the stock lift pump, and...
2. Upgrading the diameter of the fuel line throughout the system to promoter better fuel volume.
With those 2 accomplished, the injector pump itself appears fully capable of long life and reliable operation - apparently, low fuel pressure and volume TO the injector pump is the basic culprit... :rolleyes: :(
But I *still* wonder what the "improvement" was supposed to be in the later lift pumps - they surely didn't switch them for no reason at all...
I just replaced mine yesterday at 18k miles on my 2002. On my 1998, I replaced it 7 times in 98k miles. Time to get a pusher pump installed I think.
Joel
Our 2002 only has 7800 miles, but it's still producing 16+ PSIG at idle and around 12 PSIG at WOT towing our 5ver. Not much different from new performance, at least yet! :rolleyes:
Rusty
Gary, here's a list of lift pump revisions that was posted by C1B1DIESEL a couple of months ago (thanks!):
here is a little history on the lift pumps and what changes were done to them and part Numbers. hope this helps
this is long. dont ask were it came from and i will not have to lie
CORRECTIVE ACTION SUMMARY
Below is a breif history of Lift Pump Part Number and associated
design/product changes:
12V 24V
3943467 3942802 Initial ISB Production
3944818 3942802 Added "saw cut" to the motor casing to better
detect leaks during production
3944508 Stainless Steel Valve Seat/Bronze Bushing for
the Internal Pressure Regulator
3945812 3945813 Some lift pumps were having a problem with
the internal wiring shorting to the magnet sleeve. The wiring
insulation was inadvertantly being
stripped from the wiring during assembly and during pump operation the
wires are shorting to the magnet sleeve.
Federal Mogul has changed the angularity of the wire lugs in the bottom
of the pump so the wires will enter behind the
magnet sleeve in a more direct manner, thereby reducing the chances of
stripping
the insulation. They also changed their end
of the line testing to look for this shorting problem during pump
operation. Federal Mogul is also adding a
radius to the top and the bottom of the magnet sleeve where the wires
travel behind the sleeve.
3948431 3948432 Corrosion of the connection of the pig tail
at the bottom of the pump was being seen. This was found to be to the
result of road salt acting as an electrolyte.
The electrical eye terminal was changed by the vendor from brass to
bronze. No corrosion is evident during similation
and salt fog tests with the bronze terminal. The mechanical properties
of the bronze meet or exceed that of the
brass and the vendor did conduct vibration test for further
verification. To further aid in corrosion
resistance, grease was added to each terminal at the Engine plant during
assembly.
3946151 3948070 The lift pump was updated with an
integral electrical connector. The integrated connector eliminates the
need for a pigtail type harness on the pump
and will eliminate the exposure of the pigtail to environmental elements.
Also updated was EMI reduction for the pump
due to an added capacitor to the internal circuit board and a Ferride bead
added to the connector.
3948431 (12V) and 3948432 (24V) where still
kept available for service because the wiring harness on older engines
where not long enough to plug into the integral adapter.
3938367 3938368 It was found the bearing material used
for the MFR. of bearings was not consistently uniform,leading to
variance in the pump performance. This
leads to change the bearing material to sintered iron from bronze.
There was also a change in armature shaft
geometry to straight one reduces the 100% inspection of the shafts.
These pumps have the integral connector.
For service, 3948431 (12V) was superceded to
3938435 (12V) and 3948434 (24V) was superceded to 3938436 (24V).
These pumps still maintain the pigtail wiring harness.
3990082 This is a service kit supercedes
3948431(12V). It includes 3938367 (12V) and a jumper harness (4025182) so
that it can be used on older engines with the
shorter lift pump connection wiring harness. 3938436 (24V) was superceded
to 3938368 (24V), but a kit was not created to
included the jumper harness, 4025182 must be ordered separately.
3990105 3990106 The lift pumps have been updated to include
hardened valve seat to reduce valve wear. The pump also reverts to a
prior use RFI circuit board due tocomponents being
detached and jamming the pump.
Service kit 3990082 was updated to include
3990105 (12V). 3938368 (24V) was superceded to 3990106 (24V), but a kit
was not created to included the jumper harness,
III. IMPLEMENTATION SUMMARY
The supplier started building pumps with these corrective actions in the
first week of May 2001. The latest lift pumps, part number 3990105 and
3990106 when into production
WOW! Thanks for the VERY informative post Steve - looks like there's been LOTS of attention and effort taken to correct our problems with these pumps - and looks like there have been even MORE revisions since THAT list was first posted:
"The supplier started building pumps with these corrective actions in the
3990106 when into production"
I have noted that the latest part #'s for these pumps now have an "AA" extension added - so I guess they are STILL working on them!;)
Steve (or anyone in the know), had mine replaced 2 weeks ago. After they were finally convinced that the lift pump was bad (and that I knew a bit more than their common customer ) my dealer told me that they were given a number by the Star line (that number to be the most recent and not to use anything different), the pump was ordered while they were on the Star line, and they just soo happened to have 1 left in stock... (the parts manager ordered a few before they went on restriction).
It was DC p/n 5080885-AA. .
They showed me the box with the number on it and it was the same number the tech jotted down on his pad when he was on the phone (so he told me, I saw his writting, just dont know if it was really before or after he went into the stock room).
I know the AA in the part number is the initial release of the part, so it cant be the same part number for DC that covers the whole range of changes... other wise it would be AM or something like that... after 12 or 13 changes.
How does the DC p/n jive with the above numbers from ( I guess ) Cummins?
Thanks
Bob
My dealer replaced mine with one that came from STAR also. While they had several in stock at the dealership, they werent allowed to use one of these under the warranty's provisions-according to STAR. Those pumps in stock were for NON-warranty customers only. Figure that one out.
