Does anyone know what will cause the Datalink (-) fuel injector pump rectangular signal to flip, long rectangular wave to very short duration spike pulses to slightly longer duration pulses???? This seams to happen once every 3/4 of a second . Has anyone got any spects on the electronic signal requirments of the Bosch VP-44 pump ??For have been analizing them for some weeks and have a 1 volt ptp with alot of spiking in the signal
for the Fuel injection pump sync Signal is this suposed to be a square wave??? Mine isn't For it has a spiked notch taken out. The low idle select is to me avery poor signal also. Any and all info will be much appreaciated and used for I'm determined to fix this ENGINE BUCKING . Was able to find out yesterday thjat there is a" BREAKOUT TOOL" for isolating the engine and Vp-44 from the rest of the componants others might want to use this info to get some problems fixed . It is interesting when you tell a dealer about this they say they have this and canuse it but don't tell you before hand. Then he tells me that I could still be fighting this in a YEARS TIME" NOT BLOODY LIKLY "three and a half years is mor than enough.
