I decided that I needed a fuel pressure gauge. I also decided to get the DiPricol one. so far so good.
The problem is that the only single gauge pod (other than the SRT-10, which I have for EGT/Boost) is the column pod. And it's on the wrong side. I'd be willing to give up seeing the Cruise Control Indicator, but not the Odo.
So, then, I am going to get the 2-gauge windshield mount (above the rear view) - the only question is, what other gauge to get?
choices are:
- trans temp (I have a NV5600)
- engine oil temp
- oil pressure
- differential temp
what would YOU do?
thanks.
choices are:
- engine oil temp
- oil pressure
- differential temp
what would YOU do?
thanks.
