Simple Upgrade???
Axle splines???
Calling all brake gurus
rjrkihap
Does one of the "boxes" have the ability to only adjust timing and leave the fueling alone (stock)? Would simply adjusting timing give you a bit more power and improve your mileage while avoiding any potential problems with the VP44 since you are leaving the fueling parameters completely stock?
Just a thought.
Ron
I think the EZ does. It has 3 settings and I believe one is timing only, and the others timing and fuel. I don,t know about the others. :)
The Diesel Dynamics True Torque Power Module (TTPM) is the only timing only box out there that I am aware of. It is basically an Edge EZ with DD parameters. The EZ does not have timing only. All of the other "mild" boxes do some fueling.
