I'm mainly stock (for now), but I moved my OEM Carter down to the frame by the tank, did the AN-6 from the tank line as it comes over the frame, to a inline filter, to the repositioned OEM, then on to the filter input, AN-6 from the filter output to the VP44. Extended the LP wiring with a Cummins pigtail with a 5' splice of marine grade wire (better corrosion resistance) and put that in a 1/4" wire loom. Glad I did that when I changed the transmission hot line a loose fitting sprayed ATF everywhere down there, but the wires were protected.
I am very happy with mine. The fittings were a little pricy though. One of the things I like best is I can hear the LP on startup, at stop lights, and up to about 30mph. It is a nice little comforting whine as an audio check it is running. Doesn't mean it is pumping of course, gauges for that.
atbgo,
Bob Weis
