Looking for some pointers on installing the Sirius receiver. I bought the Mopar kit for the '03 and can't figure out the mounting placement for it. Instructions say to mount using bolts for brake light switch. The switch is welded and the pb switch looks out of the question. It appears it would work with bolts that hold the main wire harness but unit is to wide and inter fears with clutch pedal or firewall depending on orientation. Has any one installed in a '03 with a manual trans? If so I would appreciate some insight. The system is operational but would like to mount it correctly.
