size tires on 6inch lift
Leak at power steering pump
i got the truck lifted today, and got it at tire shop tonight, too late to try anything, but, they think the 37's will be too big, atlease too big with mud flaps in the front... when wheel cut whole way appears to want to cut into mud flaps, not sure though, havnt put on wheel yet... cant take off work for this, work mon-fri, and if tires dont fit, i cant do anything/order new till sat, and i dont want to drive with lil mini van tires. some im kinda... anxious about this, worried :(
JDerbedrossian said:
37's no problem
Watch your back spacing and how wide a wheel you go with for that combo. I have 35" Parnelli Jones on 10" wheels and the wrong back spacing and they rub with the 6" lift. The 37" would not even be able to turn with the crappy wheels I have. Live and learn. I know Fabtech and SuperLift give you the wheel size and BS you need to clear. I think it is a 17"x8" with a 4-5/8 Back spacing. Good luck
I have a 6 inch lift on my 05 and I am running 37-12. 50-R17 Goodyear MTR's. I have tried to make them rub and I have not had them do it yet. I do not have any mudflaps on the front though.
I have a 6" lift on my truck and have 37-13. 50-R17 Toyo Open Country MT's on my truck. It doesn't rub at all. I dont have the mudflaps though.
I only have the 5in lift from Skyjacker, which is actually a 4. 5in front spring and who knows rear add a leaf. Running stock wheels and 37X12. 5X17's and haven't rubbed yet, not even close, but like SLJolley said, no mudflaps. So you should be more than fine with a 6in lift!
i got the 37 12. 5 17 mtrs on now, they fit, little rubbing when wheel cut whole way and on a hill. not too bad though :)
