Anyone running windows has a program called paint. You can size pictures in there. Pretty easy too.
Click START - PROGRAMS - ACCESORIES - PAINT.
Once inside the Paint program open the file you want to size and then go to EDIT. Press select all. The go to IMAGE and select ATTRIBUTES. You can size it from there. You can also drag the corners to size pictures.
It is a pretty straight forward program. I just played with it a while to size for an AVATAR and the attached pic.
Good Luck
Garrett
Good Luck
Garrett
