Off Roading Skf Or Timken Hub Assy
Competition 1/4 mile video of my truck + 13 sec. race rig
Off Roading Hangers and Shackles
local skf hub goes for 233. 00 best price found for timken on e-net was 245. 00free shipping. I dont want the free spin kit. just looking for the better one to go with. (should I replace the axle u-joint while im there). thanks
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-FE TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED AND STUDS, AFE/2:eek: " 4"EXHAUST D/PRICOL GAUGES, FASS 150, VULCAN 1/2 DRAW-STRAW, 3/8 FUEL LINE, DSS-TRAC-BAR STEER-BOX, AIR BAGS,17'' KMC BLACK HOSS, 315/70/17 MICKTHOM MTZ'S 6" RCD LONG ARM LIFT AND DE-BADGED FOR FUEL MILEAGE. :-laf... THANKS RIP Source Automotive Performance Diesel - Home
I don't know the SKF name myself, maybe someone else can help but I know Timken is a good name. Carefully feel the joints while leaving the axles in place and if they are tight and smooth don't bother. If you pull the axles to change joints you will disturb the seals and risk a lot more work later assuming they are not already leaking.
thanks I since have replaced the hub with the skf and didnt do the u-joint it was fine 233. 00 for the skf hub from schucks auto. napa wanted 410. 00 for the same skf hub got it installed for just over 90. 00 at big o tire. thanks
I replace the hub on my '03 3/4 ton suburban. Didn't check Napa but Autozone, Advance and Pep Boys. Advance had two options... the one made in CHina or the one made in Taiwan. I chose the one made in Taiwan as I've never had any luck with stuff like that from China. I don't remember the name brand but SKF sounds familiar.
if I remember right skf was owned by the swedes. in 2005ish chicago rawhide bought skf but this doesnt mean that the hub was made in usa or china or even hell dont know where it came from just where the company is from but it looked like a solid built unit at least.
