Hope you are happy with your purchase. I have used bobcat and case mostly and between the two I would take the case anyday as the bobcat is hard to see out of the back of. I don't have much experiance with the deese's but we seem to sell a lot of them at work, just watch what you put into it for hyd fluid. I belive that should have the low-vis hygard. It is a 10 wht oil as opposed to the 30 wt of their conventioal. Just check with your local service manager before you fill, I know the new ones are the low-vis and if filled incorrectly the pump will suffer a bad future.
