I had the full 2 1/2" Double Flex Skyjacker kit installed, with the exception that I did NOT have the rear add-a-aleaf springs installed. I'd have to say the front is now either perfectly level, or maybe just ever so slightly nose high now. Galen is correct, I ordered the sway bar reloaction brackets from Skyjacker, installed them this weekend. The sway bar end links are once again straight up and down as they shoyuld be. However, I do believe the reason they got out of whack was solely due to the changing to new control arms. I kept my OEM control arms and coil springs, so I was able to measure the old and new control arms bolt hole to bolt hole. My OEM control arms are something like 17 1/2" and 18 5/8" if memory serves from yesterday morning. On my new arms, they are like 20+" on each one, and if you look at the truck from a side view, the front tires are very obviously too far forward in the wheel wells. I have thought about jacking the frame up on jack stands and trying to adjust the Skyjacker arms until they are as close as possible back to the OEM position, but haven't done so yet.
Tom
