I have been thinking (I know I know) about the cab to sleeper connection on my Inter-trash-anol proj. Have got the rear suspension mounted and pun kin dropped in/new S cams,air brake cans,new brake shoes and drums , associated hardware,suspension re bushed, new axle bearings, air bags looked to be new. Drive shaft being built as we speak.
Thinking ahead about the cab to sleeper connection. I'm going to cut the back of the cab out the same as the sleeper. On the cab of the truck just under the rain gutter I can slide the sleeper under that lip the sleeper also has a lip that will put it at the right level. The actual connection of the two will be done with Huck-a - bolts ( I'm not sure about the spelling on that)Air craft use these big time. My question is what to put between the cab and sleeper to make it water tight. I have never had a sleeper off any of my trucks. You Big Rig mechs have had to seen whats there. I'm also extending the cab frame to support the sleeper and all will be mounted to an air ride cab suspension.
Thanks for any help
BIG
Thanks for any help
BIG
