AMink
I'm trying like heck to get out of town and it's one thing after another! Yesterday I found the hydraulic reservoir was low so I added per directions. The slide worked fine again. Today I go out and try to bring the slide in and it gets half way and the pump quits. The designated fuse is fine. I tried the switch on the pump itself; no go. I ended up using the manual hex drive and got it in with a drill. So it appears there is fluid to work the ram, but I'm wondering where the power went. Is there another fuse I need to look for perhaps? I'm not overly familiar with hydraulics so I'm not sure where to start.
By the way, if you have an RV with a slide out, make sure the pump is installed so you can get a drill into the manual screw! My pump was put in so that I couldn't; had to unbolt it and rotate it to get at the screw!
