Engine/Transmission (1998.5 - 2002) slides into second gear
2nd Gen Non-Engine/Transmission Leveling Kits
Engine/Transmission (1998.5 - 2002) Radiator Block
my 1-2 shift suck lately, it doesent shift to second as it should It slides into second. All thats done to the trans is the line pressure is turned up a lil bit. it does it on half throttle shifts and higher. any suggestions on if there is a major issue.
your just taking after your big brother, oh yea thanks for starting the thread i said i was going to for 6 months now...
checked the front band adjustment the other day, it helped full throttle shifts
they are firm but half throttle still sucks. I adjusted the band 2 turns out instead of what d/c says 1,7/8.
I have the same problem.
So far I connected a guage to the governer port to watch the pressures as the shifts happen, do they happen at about the correct pressures. My 3-4 shift the pressure goes to line pressure before the shift occures if it occures at all by feel.
My next thing to check was the tv cable adjustment. Exactely HOW did you check the adjustment?
Bob Weis
I searched for how to check/adjust in the forums and found a few, all it takes is pulling the cover off the apps and checking the lower cable for slack or it being too tight. I pulled off the cable and eyeballed the cable to the clip on the apps. this is straght from the manual
ADJUSTMENTS - TRANSMISSION THROTTLE
VALVE CABLE
A correctly adjusted throttle valve cable will cause
the throttle lever on the transmission to move simultaneously
with the throttle body lever from the idle
position. Proper adjustment will allow simultaneous
movement without causing the transmission throttle
lever to either move ahead of, or lag behind the lever
on the throttle body.
ADJUSTMENT VERIFICATION
(1) Turn ignition key to OFF position.
(2) Remove air cleaner.
(3) Verify that lever on throttle body is at curb idle
position (Fig. 226). Then verify that the transmission
throttle lever (Fig. 227) is also at idle (fully forward)
position.
(4) Slide cable off attachment stud on throttle body
lever.
(5) Compare position of cable end to attachment
stud on throttle body lever:
² Cable end and attachment stud should be
aligned (or centered on one another) to within 1 mm
(0. 039 in. ) in either direction (Fig. 228).
² If cable end and attachment stud are misaligned
(off center), cable will have to be adjusted as
described in Throttle Valve Cable Adjustment procedure.
1 - THROTTLE LINKAGE
2 - THROTTLE VALVE CABLE LOCKING CLIP
3 - THROTTLE VALVE CABLE
1 - THROTTLE VALVE CABLE
2 - CABLE BRACKET
3 - THROTTLE BODY LEVER
4 - ACCELERATOR CABLE
5 - SPEED CONTROL CABLE
THROTTLE VALVE CABLE (Continued)
(6) Reconnect cable end to attachment stud. Then
with aid of a helper, observe movement of transmission
throttle lever and lever on throttle body.
² If both levers move simultaneously from idle to
half-throttle and back to idle position, adjustment is
correct.
² If transmission throttle lever moves ahead of, or
lags behind throttle body lever, cable adjustment will
be necessary. Or, if throttle body lever prevents
transmission lever from returning to closed position,
cable adjustment will be necessary.
ADJUSTMENT PROCEDURE
(1) Turn ignition switch to OFF position.
(2) Remove air cleaner if necessary.
(3) Disconnect cable end from attachment stud.
Carefully slide cable off stud. Do not pry or pull
cable off.
(4) Verify that transmission throttle lever is in
fully closed position. Then be sure lever on throttle
body is at curb idle position.
(5) Pry the T. V. cable lock (A) into the UP position
(Fig. 228). This will unlock the cable and allow for
readjustment.
(6) Apply just enough tension on the T. V. cable (B)
to remove any slack in the cable. Pulling too tight
will cause the T. V. lever on the transmission to
move out of its idle position, which will result
in an incorrect T. V. cable adjustment. Slide the
sheath of the T. V. cable (D) back and forth until the
centerlines of the T. V. cable end (B) and the throttle
bell crank lever (C) are aligned within one millimeter
(1mm) (Fig. 228).
(7) While holding the T. V. cable in the set position
push the T. V. cable lock (A) into the down position
(Fig. 228). This will lock the present T. V. cable
adjustment.
NOTE: Be sure that as the cable is pulled forward
and centered on the throttle lever stud, the cable
housing moves smoothly with the cable. Due to the
angle at which the cable housing enters the spring
housing, the cable housing may bind slightly and
create an incorrect adjustment.
(8) Reconnect the T. V. cable (B) to the throttle
bellcrank lever (C).
(9) Check cable adjustment. Verify transmission
throttle lever and lever on throttle body move simultaneously. acket of the cable itself.
Thank you Lotero for this post
I Just recently installed a 2000 Engine in my 2001 3500 and in order to make room had to bend the APPS in a 180* loop when I slipped it off to the side of the engine bay/ I must have stressed the cables when I did this and I made a mental note to check the cables on install but that was after 2 1/2 weeks later and never did/ I have been having terrible shifts out of 1st and quick shifts and down shifts that I never had experienced before/ Its the same transmission, so I figured it must have been something I did/
Your excellent post brings me to go thru the adjustment process/ Thank you for your post/ Warren
