Sliding Hitch Lube.
how heavy can you tow in overdrive?
Lost a wire on the way home
Caterpillar Dry Film lube # 222-3116. I got some at work and they use it on Backhoe extention booms. It works well and no greasy mess. It sprays on and dries in minutes.
I use regular old dish soap
just pour it on and carry a spray bottle of water with you. Wet it down before you slide it. When it gets diry just wash it off.
Jason
Or you can go to a farm supply store and get what is called plow coat or slip plate. Basically the same stuff.
I've gotten the slip plate from the Case-IH dealer. They use it with the seed drums on the planters where the drum runs against the hopper while planting.
