slight haze using exhaust brake
Wheel opening moldings
Help - Fuel Filter Replacement
Do any of you guys see a slight haze while using your exhaust brake? I only see it at night with head lights directly behind,I sure hope it's not an indication of an engine problem as I only noticed it recently.
Ramman, I wouldnt lose any sleep over it until it's visable during the day.
Whenever there is a car behind me at night, I always see a slight haze. #ad
Hell, I even see it during the day when it's cold out and it's warmed up. #ad
Eric
98 Quad cab 4X4 2500 12 valve,5 speed,3. 54 rears, 8' bed. Michelin 275 75 16 lr-E. Boost and egt gauges but basicly stock except for a "properly adjusted" AFC. Cat in the garage. Uniden HR 2510, Texas Star 1200 amp. 63,000 Mi as of 1/27/01.
NRA life member. High power/IDPA.
Ramman, I have a BD e-brake on my 97 and with the stock 215 injectors I get a slight haze when the exhaust brake is activated. This condition is also compounded by bigger injectors and your "no air " fuel setting.
97 SLT 2500, 5sp, 3:54, 255/85/16, US Gear Under-drive, BD Hx40-16cm, BD 370 injectors, TST #10 plate, BD full 4" exhaust, Centerforce Clutch, BD Governor Kit, Rancho 9000's and a few other items with a lot more on the shelve!
