I made up two door supports with 2x4's and some carpet which made it extremely easy to replace the pins and bushings by myself. After removing the inner door panel I slid the supports under the door raising a 2x4 up to support both ends to the proper level. After disconnecting some of the wiring I unbolted just the door and slid it out far enough to access the pins which from the factory are peened over. After using a drill bit large enough to remove the rounded matl. I drove them out. I had ordered a kit on ebay which although was stated to work with my year was too small. my pins are 3/8"(. 375)make sure to check your pin size. I made my own using hardened pins and bronze bushings from TSC total cost abou$15. If I had to do it over I would use the pin/bushing kit that they carry at Pep boys in the help section(they were out of stock when I did the repair)as I had to tac weld the pins I used. Once the hinges were back together I hit them with some paint and slid the door back in which was still right in alignment with the hinge, no balancing act, cursing or anything. I could try to post a pic of the supports if you want.
