Slow again
20,000 Th Member
Latest issue number?
Got right onto the website tonioght but getting onto the forums is very slow. Finally gave up on the first gen section, even this section was slow to come on.
Stan
First thing you should do is try a tracert to see if the problem is on the backbone or with your ISP. If you are on a windows machine you can do this by bringing up a command window and then typing:
tracert www.turbodieselregister.com
You'll get a report that looks something like this:
Tracing route to www.turbodieselregister.com [69. 61. 23. 10]
over a maximum of 30 hops:
1 5 ms 4 ms 4 ms 192. 168. 2. 1
2 14 ms 34 ms 20 ms 10. 1. 0. 1
3 22 ms 30 ms 19 ms 24-56-220-113. mdmmi. voyager.net [24. 56. 220. 113]
4 * 33 ms 25 ms 65. 42. 25. 81
5 23 ms 16 ms 17 ms bb1-g1-0. lgtpmi. ameritech.net [65. 42. 245. 103]
6 21 ms 21 ms 26 ms bb1-p1-3. sfldmi. sbcglobal.net [151. 164. 189. 50]
7 67 ms 23 ms 57 ms bb2-p15-0. sfldmi. ameritech.net [67. 38. 70. 158]
8 28 ms 26 ms 29 ms core2-p6-0. crchil. sbcglobal.net [151. 164. 242. 37]
9 30 ms 27 ms 28 ms core1-p8-0. crchil. sbcglobal.net [151. 164. 188. 42]
10 28 ms 30 ms 28 ms bb1-p2-0. chcgil. ameritech.net [151. 164. 243. 45]
11 38 ms 31 ms 79 ms ex1-p1-0. chcgil. ameritech.net [151. 164. 190. 2]
12 30 ms 55 ms 35 ms 206. 220. 243. 16
13 92 ms 90 ms 93 ms pos5-3. cr02. atl01. pccwbtn.net [63. 216. 0. 26]
14 87 ms 90 ms 93 ms globalcompass. ge3-0. 3. cr02. atl01. pccwbtn.net [63. 216. 31. 134]
15 88 ms 87 ms 92 ms ge-1-atl1-cust1. globalcompass.com [66. 154. 95. 221]
16 113 ms 114 ms 125 ms 69. 61. 23. 10
Trace complete.
See on line 4 where there's an * - that's a timeout and that's at my ISP. line 3 is my cable modem, line 4 is my ISP. It doesn't get to our host facility until line 14 where it says globalcompass - that is our host. If you see timeouts or delays before that point then the problem is on the backbone or your ISP. Do the tracert more than once btw because that's just one small packet going through which may go through good once, but not the 2nd time.
I just looked over the logs and there is nothing to indicate a slowdown of any kind tonight. The DNS server is working great (that will only cause slowdowns when posting). The server load never went over 1. 3 tonight - 2. 0 is 100% loaded. Lastly, the slow query rate is at . 005% or 10. 08 slow queries per hour out of 199,973 (a slow query being longer than 10 seconds).
Thanks Steve
Guess one of these days I'll have to get rid of this dial up modem and get with the rest of the world!:rolleyes:
Stan
