Slow site and tracert
Testing Signature
Site upgrades/username and password integration
Steve/Robin, I have been having the site CRAWL lately, it is the only site I frequent that has been slow. I have been trying to do the tracert thing for you to see if it will help identify the slow spots but I cannot keep the window up to get any information from. As soon as it completes the window vanishes, it must be some sort of auto-close. I recently upgraded to Windows XP Pro, before the window stayed up and now it vanishes. What do I need to do? Thanks, Howard.
Howard
Click "Start", then "Run". In the "Run" box, type cmd and hit "Enter"
You will now have a command prompt where you can type your tracert command.
On my XP system, tracert wouldn't run unless I was in the system32 folder.
Here's one way to set it up so you can run tracert.
type path=c:\windows\system32 (use winnt instead of windows if your XP is installed in that folder)
Now you can type tracert www.turbodieselregister.com or use 216. 235. 147. 117 if you like
Doc
This site has been off and on slow for me for so long now that I've come to consider it as normal. Doesn't seem to matter if it's during off peak hours. Tracerts have come back as acceptable. When it gets real bad I just go elsewhere...
I noticed the same thing off/on slow delivery on forum pages:
Microsoft Windows 2000 [Version 5. 00. 2195]
(C) Copyright 1985-2000 Microsoft Corp.
C:\>tracert www.turbodieselregister.com
Tracing route to www.turbodieselregister.com [216. 235. 147. 117]
over a maximum of 30 hops:
1 <10 ms <10 ms <10 ms 192. 168. 2. 1
2 16 ms <10 ms 16 ms adsl-157-175-1. shv. bellsouth.net [66. 157. 175. 1]
3 16 ms 16 ms 15 ms adsl-81-248-1. shv. bellsouth.net [65. 81. 248. 1]
4 16 ms 16 ms 15 ms 205. 152. 250. 249
5 15 ms 31 ms 32 ms 205. 152. 250. 49
6 31 ms 31 ms 31 ms host-209-149-134-184. btr. bellsouth.net [209. 149.
134. 184]
7 31 ms 32 ms 46 ms 500. POS1-0. GW5. HOU7. ALTER. NET [65. 208. 85. 17]
8 32 ms 31 ms 47 ms 125. at-6-0-0. XR2. HOU7. ALTER. NET [152. 63. 100. 150]
9 31 ms 31 ms 31 ms 0. so-0-0-0. XL2. HOU7. ALTER. NET [152. 63. 102. 17]
10 31 ms 31 ms 47 ms 0. so-0-0-0. TL2. HOU7. ALTER. NET [152. 63. 101. 193]
11 63 ms 62 ms 63 ms 0. so-4-0-0. TL2. ATL1. ALTER. NET [152. 63. 101. 49]
12 63 ms 62 ms 63 ms 0. so-7-0-0. XL4. ATL1. ALTER. NET [152. 63. 86. 102]
13 47 ms 78 ms 63 ms 194. ATM4-0. GW4. ATL3. ALTER. NET [152. 63. 81. 53]
14 78 ms 78 ms 94 ms internap-gw1. customer. alter.net [157. 130. 89. 90]
15 62 ms 79 ms 78 ms border4. ge3-0-bbnet2. acs. pnap.net [64. 94. 0. 73]
16 47 ms 62 ms 78 ms mariet-2. border4. acs. pnap.net [64. 94. 3. 98]
17 63 ms 62 ms 63 ms Router-5-MFN-Atl. capitalinternet.com [216. 235. 14
6. 246]
18 63 ms 78 ms 63 ms 216. 235. 147. 117
Trace complete.
2 16 ms 15 ms 16 ms adsl-157-175-1. shv. bellsouth.net [66. 157. 175. 1]
5 31 ms 16 ms 31 ms 205. 152. 250. 49
6 32 ms 31 ms 31 ms host-209-149-134-184. btr. bellsouth.net [209. 149.
134. 184]
7 32 ms 31 ms 47 ms 500. POS1-0. GW5. HOU7. ALTER. NET [65. 208. 85. 17]
8 31 ms 31 ms 47 ms 125. at-6-0-0. XR2. HOU7. ALTER. NET [152. 63. 100. 150]
9 32 ms 31 ms 31 ms 0. so-0-0-0. XL2. HOU7. ALTER. NET [152. 63. 102. 17]
15 63 ms 78 ms 78 ms border4. ge3-0-bbnet2. acs. pnap.net [64. 94. 0. 73]
16 46 ms 63 ms 62 ms mariet-2. border4. acs. pnap.net [64. 94. 3. 98]
6. 246]
18 63 ms 78 ms 62 ms 216. 235. 147. 117
Trace complete.
C:\>time
The current time is: 21:13:55. 34
Enter the new time:
2 <10 ms 15 ms 16 ms adsl-157-175-1. shv. bellsouth.net [66. 157. 175. 1]
4 16 ms 15 ms 16 ms 205. 152. 250. 249
5 32 ms 31 ms 31 ms 205. 152. 250. 49
134. 184]
7 31 ms 31 ms 47 ms 500. POS1-0. GW5. HOU7. ALTER. NET [65. 208. 85. 17]
8 31 ms 32 ms 47 ms 125. at-6-0-0. XR2. HOU7. ALTER. NET [152. 63. 100. 150]
13 63 ms 62 ms 63 ms 194. ATM7-0. GW4. ATL3. ALTER. NET [152. 63. 81. 61]
14 79 ms 78 ms 93 ms internap-gw1. customer. alter.net [157. 130. 89. 90]
6. 246]
Trace complete.
1 16 ms <10 ms <10 ms 192. 168. 2. 1
3 16 ms 15 ms 16 ms adsl-81-248-1. shv. bellsouth.net [65. 81. 248. 1]
5 16 ms 31 ms 31 ms 205. 152. 250. 49
6 31 ms 31 ms 32 ms host-209-149-134-184. btr. bellsouth.net [209. 149.
134. 184]
10 32 ms 31 ms 47 ms 0. so-0-0-0. TL2. HOU7. ALTER. NET [152. 63. 101. 193]
11 62 ms 63 ms 62 ms 0. so-4-0-0. TL2. ATL1. ALTER. NET [152. 63. 101. 49]
12 62 ms 63 ms 62 ms 0. so-7-0-0. XL4. ATL1. ALTER. NET [152. 63. 86. 102]
13 63 ms 62 ms 47 ms 194. ATM7-0. GW4. ATL3. ALTER. NET [152. 63. 81. 61]
14 78 ms 94 ms 78 ms internap-gw1. customer. alter.net [157. 130. 89. 90]
15 62 ms 78 ms 78 ms border4. ge3-0-bbnet2. acs. pnap.net [64. 94. 0. 73]
16 62 ms 63 ms 62 ms mariet-2. border4. acs. pnap.net [64. 94. 3. 98]
17 62 ms 63 ms 62 ms Router-5-MFN-Atl. capitalinternet.com [216. 235. 14
6. 246]
Trace complete.
C:\>time
The current time is: 21:15:54. 06
Enter the new time:
C:\>
BTW time is for central zone.
I wonder if the servers are starting to strain under 326 users? I think it is great that the member/guest count is going up!
Like Doc said if you bring up a command window it won't go away. You can also just put this in the run window
tracert www.turbodieselregister.com > c:\tracert. txt
and it will put the tracert in the c:\tracert. txt file that you could then copy and paste into a message rather than retyping it yourself. I'm on the site all times of the day every day and have seen very few times that it's slow. When it has been slow every time it's been something between me and the ISP since the last go around with slow downs at the ISP (about a month or so ago). Last night there was a MAJOR problem with the internet backbone in the chicago area that caused problems for me. Illflem - when it's slow for you please make a copy of that tracert and email it to me or post it on here so I can check it out.
In looking at the server logs we aren't seeing excessive server loads at all. Looking at the SQL server info (which serves up all the data for the forums) there are an average of 15. 5 slow queries per hour out of 92981 (slow being defined as greater than 10 seconds) or . 017% of queries.
The highest load on the server in the last few days is 1. 19 - it's a dual CPU system so a 100% load is 2. 0 . So the server isn't getting loaded up. When you say slow response in the forums how slow are you talking about?
Slow is a relative term, that said, under normal conditions the forum loads as soon as I click on the next link. On slow speed a pause of 3-5 seconds between mouse action and loading of the page. Extreme slow is 15 seconds and that is 5% of the slow loads, which is about 3% of my total surfing on the forums. So I guess this all adds up to DSL has spoiled me rotten, and I was wanting to provide feedback from the field in case there was something more to it than my impatience.
Thanks!
PS Thanks for all the hard work and the AWESOME SITE!
Got this one tonight at 1837hrs from Wash D. C.
1 20 ms 20 ms 10 ms 10. 1. 65. 1
2 10 ms 20 ms 10 ms A7-0-31124. Q-GSR1. RES. verizon-gni.net [151. 200.
. 210]
3 10 ms 20 ms 20 ms dca-edge-01. inet. qwest.net [63. 148. 64. 221]
4 10 ms 20 ms 20 ms dca-core-03. inet. qwest.net [205. 171. 9. 85]
5 20 ms 20 ms 20 ms dca-core-02. inet. qwest.net [205. 171. 9. 49]
6 30 ms 40 ms 30 ms atl-core-02. inet. qwest.net [205. 171. 8. 153]
7 30 ms 31 ms 30 ms atl-core-01. inet. qwest.net [205. 171. 21. 149]
8 30 ms 30 ms 30 ms atl-edge-08. inet. qwest.net [205. 171. 21. 90]
9 30 ms 30 ms 40 ms internap1-customer. qwest.net [63. 144. 1. 170]
10 30 ms 30 ms 40 ms border4. ge3-0-bbnet2. acs. pnap.net [64. 94. 0. 73]
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24
That's a backbone problem shovelhead and just outside of your ISP too. That's something between your ISP and our hosting facility - nothing we could ever have control over. Thanks for the info.
Just trying to see if we can all figure out what's going on. ;)
Sometimes I click and the next page jumps right up, other times click and it will take 1 or 2 minutes to load a page.
Strange... ... ... ... ..... but maybe it's just a bunch of holiday shoppers clogging up the works. :rolleyes:
Thanks for doing a great job tryin' to keep us all happy Steve. :cool:
Wazzzzup Doc?
(just seems to fit don't it?)
Good to see 'ya back. ;)
Havin' any luck wood gathering?
You know your UPS guy is gonna be lookin' for HUGE tip when he makes that delivery. :D
Steve, sorry I have not responded, I was out of town.
By slow I mean over 15 seconds for a new query, sometimes it is over 60 seconds to open a new forum.
I will have to try the . txt thing, the command window will not stay open either. Next time it is happening I will get some info for you. Thanks.
--- 12/08/02 14:33:09 Pacific Standard Time
--- looking up host www.turbodieselregister.com
--- traceroute to www.turbodieselregister.com [216. 235. 147. 117],
30 hops max, 18 byte packets
1 [ 192. 168. 2. 1] 192. 168. 2. 1 1 ms
2 [ 209. 53. 1. 230] 209. 53. 1. 230 29 ms
3 [ 209. 53. 1. 190] vancbc01dr11. bb. telus.com 30 ms
4 [ 154. 11. 10. 65] vancbc01dr01. bb. telus.com 31 ms
5 [ 204. 174. 217. 5] nwmrbc01gr01. bb. telus.com 29 ms
6 [ 154. 11. 10. 53] nwmrbc01br01. bb. telus.com 57 ms
7 [ 209. 53. 75. 178] sttlwa01gr02. bb. telus.com 58 ms
8 [ 154. 11. 10. 2] plalca01gr00. bb. telus.com 56 ms
9 [ 154. 11. 3. 14] peer. plalca01gr00. bb. telus.com 56 ms
10 [ 205. 171. 205. 29] 205. 171. 205. 29 57 ms
11 [ 205. 171. 14. 121] svl-core-01. inet. qwest.net 58 ms
12 [ 205. 171. 8. 130] iah-core-01. inet. qwest.net 119 ms
13 [ 205. 171. 31. 6] iah-core-03. inet. qwest.net 119 ms
14 [ 205. 171. 8. 146] atl-core-01. inet. qwest.net 118 ms
15 [ 205. 171. 21. 90] atl-edge-08. inet. qwest.net 117 ms
16 [ 63. 144. 1. 170] internap1-customer. qwest.net 226 ms
17 [ 64. 94. 0. 9] border4. ge2-0-bbnet1. acs. pnap.net 219 ms
18 [ 64. 94. 3. 98] mariet-2. border4. acs. pnap.net 222 ms
19 [216. 235. 146. 246] Router-5-MFN-Atl. capitalinternet.com 223 ms
20 [216. 235. 147. 117] www.turbodieselregister.com 230 ms
--- traceroute statistics for www.turbodieselregister.com
20 packets transmitted, 20 received
round-trip time (ms) min 1, avg 102, max 230
--- 12/08/02 14:33:30 Pacific Standard Time
1 [ 192. 168. 2. 1] 192. 168. 2. 1 0 ms
7 [ 209. 53. 75. 178] sttlwa01gr02. bb. telus.com 57 ms
8 [ 154. 11. 10. 2] plalca01gr00. bb. telus.com 55 ms
9 [ 154. 11. 3. 14] peer. plalca01gr00. bb. telus.com 55 ms
13 [ 205. 171. 31. 6] iah-core-03. inet. qwest.net 120 ms
14 [ 205. 171. 8. 146] atl-core-01. inet. qwest.net 120 ms
15 [ 205. 171. 21. 90] atl-edge-08. inet. qwest.net 119 ms
16. *
17 [ 64. 94. 0. 9] border4. ge2-0-bbnet1. acs. pnap.net 101 ms
18 [ 64. 94. 3. 98] mariet-2. border4. acs. pnap.net 102 ms
19 [216. 235. 146. 246] Router-5-MFN-Atl. capitalinternet.com 106 ms
20 [216. 235. 147. 117] www.turbodieselregister.com 107 ms
20 packets transmitted, 19 received
round-trip time (ms) min 0, avg 71, max 120
--- 12/08/02 14:41:14 Pacific Standard Time
4 [ 154. 11. 10. 65] vancbc01dr01. bb. telus.com 29 ms
12 [ 205. 171. 8. 130] iah-core-01. inet. qwest.net 121 ms
13 [ 205. 171. 31. 6] iah-core-03. inet. qwest.net 125 ms
14 [ 205. 171. 8. 146] atl-core-01. inet. qwest.net 119 ms
16. *
17 [ 64. 94. 0. 9] border4. ge2-0-bbnet1. acs. pnap.net 213 ms
18 [ 64. 94. 3. 98] mariet-2. border4. acs. pnap.net 206 ms
19 [216. 235. 146. 246] Router-5-MFN-Atl. capitalinternet.com 214 ms
20. *
21. *
22 [216. 235. 147. 117] www.turbodieselregister.com 222 ms
22 packets transmitted, 19 received
round-trip time (ms) min 1, avg 94, max 222
--- 12/08/02 14:43:30 Pacific Standard Time
2 [ 209. 53. 1. 230] 209. 53. 1. 230 30 ms
3 [ 209. 53. 1. 190] vancbc01dr11. bb. telus.com 29 ms
4 [ 154. 11. 10. 65] vancbc01dr01. bb. telus.com 30 ms
5 [ 204. 174. 217. 5] nwmrbc01gr01. bb. telus.com 31 ms
8 [ 154. 11. 10. 2] plalca01gr00. bb. telus.com 57 ms
12 [ 205. 171. 8. 130] iah-core-01. inet. qwest.net 132 ms
16. *
17. *
18 [ 64. 94. 3. 98] mariet-2. border4. acs. pnap.net 208 ms
19 [216. 235. 146. 246] Router-5-MFN-Atl. capitalinternet.com 230 ms
20. *
21 [216. 235. 147. 117] www.turbodieselregister.com 206 ms
21 packets transmitted, 18 received
round-trip time (ms) min 1, avg 88, max 230
--- 12/08/02 14:44:11 Pacific Standard Time
2 [ 209. 53. 1. 230] 209. 53. 1. 230 28 ms
5 [ 204. 174. 217. 5] nwmrbc01gr01. bb. telus.com 30 ms
10 [ 205. 171. 205. 29] 205. 171. 205. 29 56 ms
11 [ 205. 171. 14. 121] svl-core-01. inet. qwest.net 57 ms
12 [ 205. 171. 8. 130] iah-core-01. inet. qwest.net 120 ms
15 [ 205. 171. 21. 90] atl-edge-08. inet. qwest.net 120 ms
16. *
17 [ 64. 94. 0. 9] border4. ge2-0-bbnet1. acs. pnap.net 214 ms
18 [ 64. 94. 3. 98] mariet-2. border4. acs. pnap.net 219 ms
19. *
20 [216. 235. 147. 117] www.turbodieselregister.com 208 ms
20 packets transmitted, 18 received
round-trip time (ms) min 1, avg 87, max 219
Hey Steve!
I found out what was causing my slow forum access, I had a particular piece of software loaded to my computer and I found out it was a resource hog and was responsible for the slow screen loads. Removed the program and all is back to normal, just thought I would update you.
