I tried to search on throttle return springs etc but did not have much luck. I pulled the 4 GSKs and put the stock springs back in to get rid of a terrible (when very cold) idle rebound (bounce or what every you want to call it). With a cold start and temps below zero, the engine would die on every return to idle. I keep my idle set at 900+ BTW! I tried clicks tighter, looser, one different from the other.....
I have ran 3K and then 4K Springs for a couple years now.
The stock springs have no bounce and work pretty well. I am sure I have then a little tight as I could not drop the idle (when warm it is dead on 1000) with the idle adjustment screw. I set them the same as I had the 4 GSKs... . two full turns after the first contact. With just slight pressure on the throttle lever pushing against the idle stop it would drop a couple hundred RPMS. I would rather make a adjustment to the throttle rod (would this even help) or put a stiffer throttle return spring on then turn the GSKs looser. Keep in mind everything is factory original (other then throttle lever recall parts) with 250K + miles.
In fact if I can get a handle on the idle I would like to turn the stock springs tighter... . if I can get away with it. With a warm engine, WOT in neutral sits right at 3200. For my use these might work out.
Thanks for any help with return springs (part number???) or other suggestions.
jjw
ND
jjw
ND
