Dan_69GTX
Hi, I'm trying to help a friend with a problem - and I am stuck. Hoping someone here can help... .
His truck is a 2003 Dodge Laramie 2500 4x4 Quad Cab with the Cummins diesel & 6-speed transmission.
Here is what has been done to it before I started getting involved - I haven't done much yet.
"In his words"...
As I'm driving, it will slowly accelerate (although I keep steady pedal pressure) then all of a sudden it will quit accelerating (feels like a carb with a 7000lb return spring, the way it quits so abruptley) I then have no acceleration. It still moves, but seems like some sort of minimum loop mode. Or maybe just lucky that it will not stall at idle rpm's. I can also never tell if I will have power from a stop, as in clearing or crossing an intersection. I have had it in 4 times now. No applicable codes (although I did get charged $600 bucks for a new fan hub, and the fan now runs a lot of the time). Codes have been cleared, pc reflashed, and Thursday they installed a new ECM. But it is still undrivable.
I am about to change the Accelerator Pedal Position Sensor.
PS, The codes I get are:
P 0642
P 0 107
Searching in the archives I don't find much regarding the 0642 code.
Thanks!
Dan
"In his words"...
P 0642
P 0 107
Thanks!
Dan
