2002 6 speed manual 2500 cummins with fass ddrp mounted on frame rail, edge jwa on conservative mode for towing, lift pump wired direct to battery with relay, otherwise stock except for bigger air filter and aftermarket exhaust.
pulling 36' rv trailer to my travel job in nevada... before trip replaced fuel filter, oil, diff fluids, transmission fluids... no issues noted. had fuel pressures consistently at 16 at idle before and during the first part of the trip.... began to notice slowly decreasing lift pump pressures down from normal ~13 while towing at 55mph and ~45% load.... began to slowly creep down so that it could not maintain greater than 8-9psi towing at those speeds. appeared to be progressively getting lower over time no egt or other issues.
replaced fuel filter first.... no change. replaced fuel strainer before fass... no change. installed spare stock carter lift pump (brand new)... now even lower lift pump pressures (cannot stay above 7 psi under any normal load or accelleration without the trailer hooked up). had a dead pedal condition once after getting off at rest stop 400 miles ago, but had been running cruise control for a long time and apps immediately reset itself upon shutdown/restart.
no drivability issues at all. no change in power, just a slowly decreasing fuel pressure... now stopped in cheyenne for fear of getting into remote area and possibly killing an injection pump. i'm at a loss at this point any ideas? i have to be at my job in reno in 5 days and have at least 2 solid days of driving to do yet so any help or advice is much appreciated.
edit: forgot to mention i checked voltage at the lift pump as well and my alternator.
-thx, pat.
-thx, pat.
