I've just installed TST plate #8 (230/605 hp/lbs-ft) and I'm not getting the performance I expected from reading some of the posts here on the forum. It definately performs better, but not appreciably so. One of those "other" machines out pulled me on a mountain pass this weekend pulling about the same load. Everything else is completely stock (including air filter) except for the addition of boost and EGT gauges.
For example, I've read that for some people the filter minder moved for the first time after installation of the kit. Mine hasn't budged. I even unscrewed it and sucked on it to see if it was working. Works fine.
I've also read that @ 1500 rpm max boost should be about 30 psi when the throttle is "mashed". I've tried "mashing" the throttle and even rolling it on at 1500 rpm and I don't see a change in boost until the engine begins to rev. I tried this on a hill while pulling a boat and camper and stayed at about 12 psi and 1500 rpm for a good 10 seconds.
I'm suspicious about my cat, the pump timing (puffs a little white when starting), and fuel restrictions. I'm planning on gutting the cat as soon as possible, and I have the timing kit on order. Not sure how I'm going to check fuel flow yet.
Has anyone else had similar experiences? Am I expecting too much? Am I on the right track with my plans?
Any input greatly appreciated.
