I just got back from my 1900 mile vacation running the Smarty on 30 HP "timing" with the TST turned off the entire time. I wanted to compare driveability and mileage of the Smarty versus the TST on timing only (1 x # settings) since these are setting that I run at 95% of the time with my 90 HP injectors, which is about 400 rwHP based on previous SPS62 / TST dynos. These are my impressions:
Smarty only = Porsche
TST only = 2-stroke Yugo running on rusty rims
I had my repaired Stage 1 CP3 ready to go on, but I ran out of time to install it before the vacation. What I can say is that running the Smarty is like running the modded CP3 with a TST on 1x0 with all the INSTANT low end and smooth linear power delivery. A TST twins program with a stock CP3 is still a laggy, peaky power adder in my opinion.
The only thing that really sucks about the Smarty is running in a parking lot with speed bumps with the very touchy throttle. I was putzing through a parking lot in 1st gear and idled over a speed bump with my foot barely on the throttle while my wife was taking a sip of water and just about gave her whiplash if it wasn't for the seatbelt kicking in. Smoke is somewhat an issue just off-idle, but very much controllable - and I typically drive at 5,000 to 6,700 feet elevation. Lastly, I did get a code P0602, which is something to do with ECM programming.
I can't say exactly how much mileage gain there was because a lot of the TST miles were towing with big laggy singles or towing with the twins. However, the worst mileage during the trip was 17. 55 mpg running on the interstate at 78 mph at 5,000 feet with an 8,000 lb truck. The following is a snapshot out of my fuel mileage log since new. Interesting to note how much big, laggy singles cost you in mileage BTW!
My next test is loading the Smarty 30 HP "no timing" program and then using the TST on timing only (or add more injector duration with it). I did try running the 30 HP timing with the TST on timing and it didn't produce any weird timing rattle. The power delivery was strong and smooth on the low end and then became peaky when the TST kicked in.
[/IMG]#ad
